LeoVince X3
Verfasst: Fr 4. Nov 2005, 12:58
Hello!
I have a question...
I just bought a LeoVince X3 auspuff, for my 3TB 1991 XT600E.
Kedo.de mailed me that it will not fit unless if i make a brace myself :
its correct that the exhaust for XT600E/K before 1995 need to use the original mounting points, and thus acts like a part of the frame, or need to bring a brace ("Rahmenverbindungsstrebe") that supports the rear frame instead. Because the LeoVince exhaust is made for XT600E/K from 1995 and newer, it does use the original mounting points of the XT600E/K from 1995, not those of the XT600E/K before 1995 and it does not bring a brace. As a result, the LeoVince does not meet the needs for an exhaust for XT600E/K before 1995.
and :
yes, that could work, if you are able to build a brace yourself. As far as I know, the connection pipe of the LeoVince exhaust that connects the header pipe with the exhaust muffler does not interfere with an extra brace at the XT600E/K before 1995. Of course I do not know, if the LeoVince mounting material may be used of if there are additional parts be be made in order to fix the muffler to the frame.
Now, i held the X3 next to my orignal mounted auspuff, and i can't see a problem with connecting it (but i am an amateur). Does anybody here know something about dificulties with connecting the X3 to and older model XT600 ?
thanks!
zen
and :
thanks!
zen
