Brauchen Sie Hilfe bei der Suche alten Stil TK Ydis Sekundär Vergaser Hauptdüse
- Henner
- (verstorben)
- Kontaktdaten:
RE: Brauchen Sie Hilfe bei der Suche alten Stil TK Ydis Sekundär Vergaser Hauptdüse
Just make a call or email at Motoritz, he could help you.
Motoritz--->Teile/Service/Beratung für SR/XT/TT/XTZ/SRX/YFM 500--550--600-660
Kontakt--->Tel. +49-641-4941903 oder Mail---> mail@motoritz.de
Danke. Ich werde sie zu kontaktieren.
Thank you. I will contact them.
It may be easier to copy the English text as well, the Google translation is ... funny sometimes.
You can try to locate the part number in one of the online Yamaha parts catalogue e.g. http://www.yamaha-motor.com/home_parts.aspx
Then websearch for the part number.
It may surface in boats.net or a similar site as many parts are also used in snow scooters, outboard engines etc
Andy
Andy
Ein Deutsch tranlation dieser Stelle ist unten
Thank you for the tip. Unfortunately Yamaha no longer sells these jets. Because of this boast.net & all other distributors are now sold out. All sizes that Yamaha ever sold #125, #130 & #135 cannot seem to be found new anywhere at this time.
I wrote to Motoritz to see if they have the jets. I sure hope they do.
Danke für den Tipp. Leider Yamaha nicht mehr verkauft diese Jets. Aufgrund dieser boast.net & alle anderen Händler sind nun ausverkauft. Alle Größen, die Yamaha jemals verkauft # 125, # 130 und # 135 kann nicht scheinen, um neue überall in dieser Zeit gefunden werden.
Ich schrieb an Motoritz zu sehen, ob sie die Jets haben. Ich hoffe, dass sie es tun.
Hi
as it is a Keihin carb you may also check with Keihin directly, did you already try?
http://www.keihincarbs.com/home.html
Andy
Andy
I wish XTs had Keihin carburetors as Keihin is good at supporting its products. Unfortunately the carburetors found on XT600s are made by Teikei, a company that is not so good at product support. I have contacted Teikei but they have not contacted me back.
Here is a link to the Teikei website. http://www.teikei.co.jp/e-index.html
and here is a link to there product page http://www.teikei.co.jp/e-index.html
On the top of the product page you will see the carburetor model Y26PV. This is the carburetor that is found on more modern XT600s & TT600s. Unfortunately Teikei shows no listing of the Y27PV which is the carb found on older XT & TT600s. Teikei doesn't have any support links for the modern Y26PV let alone the Y27PV either.
For more info on what Teikei carb was installed on which year of XT this forum has a very good page for reference. Here is the link http://www.xt600.de/xt_werkstatt/_techn ... _xt600.htm
Ich wünsche XT hatte Keihin Vergaser Keihin wie gut ist auf die Unterstützung seiner Produkte. Leider sind die Vergaser auf XT600s gefunden werden durch Teikei, einem Unternehmen, das nicht so gut im Produkt-Support gemacht. Ich habe Teikei kontaktiert, aber sie haben mich nicht kontaktiert zurück. (
Hier ist ein Link auf die Website Teikei. http://www.teikei.co.jp/e-index.html
und hier ist ein Link zur Produktseite gibt http://www.teikei.co.jp/e-index.html
Auf der Spitze der Produktseite sehen Sie die Vergaser-Modell Y26PV. Dies ist der Vergaser, die auf modernere XT600s & TT600S zu finden ist. Leider Teikei zeigt keine Auflistung der Y27PV die die carb auf älteren XT & TT600S gefunden wird. Teikei keine Support-Links für die moderne Y26PV geschweige denn die haben entweder Y27PV.
Für weitere Informationen über das, was wir am Teikei carb welchem ​​Jahr der XT Dieses Forum hat eine sehr gute Seite für Referenz installiert. Hier ist der Link http://www.xt600.de/xt_werkstatt/_techn ... _xt600.htm
Ah, sorry I got the wrong name here ;( .
Anyway, Motoritz should have some carbs or parts of them.
Andy
Andy
Gelöschter Beitrag
Kein Beitrag
From Google Translate:
Hallo, ich schreibe aus Amerika. Wie so viele Amerikaner bin ich zu ungebildet, um mehr als Englisch sprechen. schrieb ich diese Meldung mit Google Translate. Ich hoffe, Google kann meine Botschaft richtig in die deutsche Sprache zu vermitteln. Sie besorgt über die Reaktion in Englisch nicht, es sei denn Sie wollen. Ich verwenden kann Google translate auf keine Beiträge zu diesem Thema zu lesen. Danke für das Lesen meiner Post. Ich hoffe jemand kann mir helfen, die Informationen finden, ich suche.
Ich habe vor kurzem erwarb 1986 eine XT600 . Es hat die älteren Stil TK Ydis Kohlenhydrate. Ich muss Hauptdüsen für den sekundären Vergaser erwerben . Ich bin für weniger als 135 Größen , aber würde jeder Größe betrachten , wie ich konnte immer löten und bohren die Größe ich brauche.
Ich habe alle über das Internet gesucht. Ich kann nicht finden , diese Jets. Yamaha ist nicht zu verkaufen. Ich überprüfte [link:www.kedo.de?f_support=www.xt600.de|KEDO] . [link:www.kedo.de?f_support=www.xt600.de|KEDO] nicht verkaufen. Ich schaute auf vielen Seiten, aber ebay könnte sie dort nicht finden entweder . Ich bin nicht sicher, wie zu verkaufen dieses Forums für die Jets zu suchen . Ich bin zu ungeschickt in der deutschen Sprache zu tun. Vielleicht sind sie hier zu verkaufen , weiß ich nicht .
Wenn Sie mir helfen können einen Platz finden , um diese Jets neu oder gebraucht kaufen wäre ich dankbar . Wenn Sie einige , nach Amerika zu verkaufen und versenden sie werde ich bei Ihnen kaufen.
Ich habe vielleicht nicht herausgefunden, wie man Bilder zu diesem Forum . Ich habe versucht, Anbringen von zwei Bilder zu diesem Beitrag. Ein Bild des Strahl Suche . Der andere ist ein Bild des Vergasers Diagramm des TK Ydis Vergaser , das diesen Strahl verwendet . Der Jet muss ich ist gelb markiert.
Wenn thepictures nicht richtig befestigen hier ist ein Link zu einem Bild von der Jet- Suche
und hier ist ein Bild von der TK Ydis Carb- Diagramm mit dem Jet in gelb markiert verknüpfen.
The same post in English:
Hello, I am writing from America. Like so many Americans I am too uneducated to speak more than English. I wrote this message with Google Translate. I hope Google can convey my message properly into the German language. Do not be concerned about the responding in English unless you want to. I can use Google translate to read any posts in this thread. Thank you for reading my post. I hope someone can help me find the information I seek.
I have recently aquired a 1986 XT600. It has the older style TK YDIS carbs. I need to aquire main jets for the secondary carburator. I am looking for sizes less then 135 but would consider any size as I could always solder & drill the size I need.
I have looked all over the web. I cannot find these jets. Yamaha does not sell them. I checked [link:www.kedo.de?f_support=www.xt600.de|KEDO]. [link:www.kedo.de?f_support=www.xt600.de|KEDO] does not sell them. I looked on many ebay sites but could not find them there either. I am not sure how to search this forum's classifieds for the jets. I am too inept in German language to do so. Maybe they are for sale here I do not know.
If you can help me find a place to buy these jets new or used I would be greatful. If you have some to sell & will ship them to America I will buy from you.
I have maybe not figured out how to post pictures to this forum. I tried attaching two pictures to this post. One picture is of the jet I am looking for. The other is a picture of the carburetor diagram of the TK YDIS carburetor that uses this jet. The jet I need is marked in yellow.
If thepictures did not attach properly here is a link to a picture of the jet I am looking for
and here is link a picture of the TK YDIS carb diagram with the jet marked in yellow.
I hope I posted in the right forum for my question. If not please tell me where I should post this instead. Thank you.
Anhang #1 (7838.jpg)
Anhang #2 (7840.jpg)
Ein Deutsches Transkript von Google Translate ist unten.
No worries about the name mix up. It is interesting that you spoke of the Keihin jets. While Keihin does not make a jet that is compatible with the secondary main jet in a TK YDIS, Keihin does make jets that are compatible as the TK YDIS primary main jet. I found this out recently through some research at a local shop. It is the Keihin 393 series of jets that will work as primary main jets for the TK YDIS of any year XT or TT that has these carbs. Maybe this trick is known to many already in Europe I do not know. Below are pics I took of the TK YDIS primary jet compared to a Keihin 393 series jet.
You guys were right about Motoritz. He had the jets I needed. They are on there way to the USA now. Thanks for helping me find him.
[h1]TK YDIS Primary Main Jet VS Keihin 393 Jet[/h1]
Keine Sorgen über den Namen mischen. Es ist interessant, dass Sie der Keihin-Jets gesprochen. Während Keihin kein Jet, mit dem sekundären Hauptstrahl in einer TK Ydis kompatibel zu machen, Keihin macht Jets, die als kompatibel TK Ydis primäre Hauptstrahl sind. Ich fand das vor kurzem durch einige der Forschung in einem lokalen Shop. Es ist der Keihin 393 Serie von Jets, die als primäre Hauptdüsen für die TK Ydis eines Jahres XT oder TT, die diese Kohlenhydrate hat funktioniert. Vielleicht dieser Trick ist vielen bereits in Europa, weiß ich nicht bekannt. Oben sind Bilder, die ich von der TK Ydis Primärstrahl im Vergleich zu einem Keihin 393 Serie-Jet.
Ihr Jungs hatten Recht über Motoritz. Er hatte die Jets die ich brauchte. Sie sind auf ihrem Weg in die USA jetzt. Vielen Dank für die Hilfe ihn finden.
