XTDM600
Theoneandonlymin
XTDM600
Beitrag von Theoneandonlymin »
My plan is to see if I can convert this, which is a running project at the moment
Into something similar to this as I never ride off road. This bike was for sale on Ebay a few years back.
Using this which I have just bought. Using the complete front end and rear wheel.
Apparently it should go together OK. I have a bare 3TB frame that I will test assemble the parts on.
Cheers
Min
Theoneandonlymin
Re: XTDM600
Theoneandonlymin hat geschrieben:
Mi 29. Nov 2023, 22:33
Bigger photos !!
Cheers
Min
Re: XTDM600
Das Ebay-Resultat schaut jedenfalls fesch aus. Bin gespannt.
Theoneandonlymin
Re: XTDM600
TDM front end is a straight swap.
Cheers
Min
Theoneandonlymin
Re: XTDM600
Rear went in OK. Just need to make up a wee spacer.
Re: XTDM600
What is a wee spacer?
derMoe
Re: XTDM600
Beitrag von derMoe »
@lowrider82
lt. Google-Übersetzer ist es ein "kleiner Abstandshalter" :D
@Min
Very Great Job!! :shock:
I'm looking forward to reading more about it... and pictures :mrgreen:
Greeeets Moe
Theoneandonlymin
Re: XTDM600
lowrider82 hat geschrieben:
Di 30. Jan 2024, 12:36
Small :D
The XT600 spacers and the brake hanger aren't quite correct. Using the XT600 caliper and brake hanger so will possibly have a disc manufactured as the TDM is of larger diameter. But that plan may change.
Tibor
Re: XTDM600
Beitrag von Tibor »
I would try the spacer if possible. The break disk is a wear part and easier to replace when it's not custom. The spacer lives forever.
Theoneandonlymin
Re: XTDM600
I bought a FZ600 rear disc. 220mm with correct bolt spacing. Now I need to use countersunk screes and mill my caliper a few mm.
But I have a bigger problem to solve at the moment!!!
My MG Stelvio 1200 engine swap.
